Discussion topic: Wifi has stopped working
This message was authored by: Martin218
My WiFi is not working middle light off the three lights is not on but have tested connection on this site and it said it was good not sure what's going on
Re: Wifi has stopped working
@Martin218
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
