Discussion topic: Wifi has gone down wont work
This message was authored by: Cmcxdbehw
Our wifi has gone down for 30minutes so far ive turnt the router off and on still not working
This message was authored by: Neil_61
Re: Wifi has gone down wont work
The TV said my WIFI was down, but my router shows 4 green lights ?
This message was authored by: Jwills77
Same in Grays - all lights on router on but WiFi won't work.
@Jwills77 @Cmcxdbehw @Neil_61
When it is down after midnight to around 6am then it could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area, it doesn't always pick up issues straight away so it might be worth trying again later if this is the case:
If there isn't try running the line test here:
