Discussion topic: Wifi failing
This message was authored by: Gary256
Wifi failing
The connection between our mobile phones disconnects regularly when we are in a different room from the router. We use iPhones, and keep having to manually reconnect to the WIFI.
Re: Wifi failing
Hi @Gary256
What is the signal strength like on the phones whent they are connected? It sounds like you may need a booster.
I am NOT a Sky Employee
