Discussion topic: Wifi dropping out
This message was authored by: Maria107
Wifi dropping out
Light is white on the hub but the WiFi keeps dropping out, ever since there was an issue in the area last week
Re: Wifi dropping out
@Maria107 if the hub indicator remains white it is remaining connected to the line. That implies the issue is within your home so check whether the issue is nit simply poor wifi if it is devices near the hub should stay connected but devices further away msy lose connection. A simple hub reboot may sort the issue if its down to interference but you may need an extender or similar to get decent wifi in every room.
