Discussion topic: Wifi dropping out for seconds
Message posted on 10 Aug 2026 09:57 PM
WiFi appears to be working but I can see it drops out and back in on multiple devices at the same time, all the time
Message posted on 11 Aug 2026 06:55 AM
Re: Wifi dropping out for seconds
@Hugh38 check the indicator lights on your hub to see if the connection to the exchange is dropping and use this guide https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 14 Aug 2026 12:05 PM
Thanks for the reply. The hub is fine and is connected consistently. The data light on the fibre thing is flickering all the time. The WiFi is defiantly dropping across all devices for a few seconds, consistently. The tests on the sky app says everything is fine.
