Discussion topic: Wifi dropping out Fife Scotland
This message was authored by: Thebow1
This has been happening since Monday. Router showing internet as ornage but power and wireless lights are green, checking online and says all is ok but it certainly isn't.
Re: Wifi dropping out Fife Scotland
@Thebow1
Avatar for Thebow1
Have tried all this multiple times looks like I'll need to phone 😡
