Discussion topic: Wifi dropping - Hove
Message posted on 21 Mar 2025 08:26 PM
Hi, I live in Hove (BN3) since last night my router keeps dropping and cutting out completely, it's been happening consistently since at least 12:30am 21st March 2025. Has anyone in the area had similar issues?
Message posted on 21 Mar 2025 08:30 PM
Re: Wifi dropping - Hove
@DJG1989
Message posted on 21 Mar 2025 08:35 PM
Hi, I've ran all the diagnostics a few times, there doesn't appear to be any issues in the area according to the app.
