1
This discussion topic has been answered Discussion topic: Wifi down
This message was authored by: BM44
Wifi down
Our WiFi disconnects about 5 or 6 times a day since we upgraded to the fibre connection. It is currently down
Re: Wifi down
@BM44
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
Re: Wifi down
@BM44
