2
This discussion topic has been answered Discussion topic: Wifi down.
This message was authored by: Whitnail
Wifi down.
I have a......
green light, no light, green light, orange light.
I've reset and pulled the plug and it's still not working.
Please help.
Avatar for Whitnail
This message was authored by: Whitnail Answer
Re: Wifi down.
Thanks for the great reply.   Unfortunately, the problem was a little deeper and they had to replace the ONT.
It's all working now.  🙂
Re: Wifi down.
@Whitnail
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Avatar for Whitnail
Re: Wifi down.
