Discussion topic: Wifi down
This message was authored by: Jonnyhoggett1
Wifi down
Hi, Having issues with my broadband, it's saying the internet is down but when I've ran a check it's saying everything is okay. Broadband is set up as normal and never had any issues.
This message was authored by: carrie+2401
Re: Wifi down
I have the same problem,
each time I try to run a service check, even that isn't working.
no wifi also equals no tv as I have sky glass. So frustrating!
Re: Wifi down
