Discussion topic: Wifi down
This message was authored by: AngelaVincent
Wifi down
Router has green lights for power & wifi but no light for internet and an amber light for voice
Re: Wifi down
@AngelaVincent
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
