1
This discussion topic has been answered Discussion topic: Wifi down
This message was authored by: Suzy38
Wifi down
WiFi not working
Re: Wifi down
@Suzy38
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Re: Wifi down
@Suzy38
