Discussion topic: Wifi down
This message was authored by: Sarah9196
Wifi down
Thefe is no connection to any devices or the skytv. The router has been switched off and on again but still nothing
Re: Wifi down
@Sarah9196
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
