Discussion topic: Wifi down
This message was authored by: OlgaWoj
Wifi down
My wifi is down everyday I'm unable to work, please fix it
Re: Wifi down
@OlgaWoj
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
Avatar for OlgaWoj
Re: Wifi down
Hi thanks.
Its been all done and its still not working
g
Re: Wifi down
@OlgaWoj
You may need to contact Sky then.
