Discussion topic: Wifi down
Message posted on 01 Jan 2025 03:24 PM
Wifi down
Wifi is not working I have done the reset etc and still not working
Message posted on 01 Jan 2025 03:32 PM
Re: Wifi down
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Message posted on 01 Jan 2025 03:48 PM
Re: Wifi down
Thanks done all advised before I put the post up
