Discussion topic: Wifi down
This message was authored by: Haddy456
Wifi down
Hello my wifi is not working, ive run diagnostic tests via the app which says everything is fine.
This message was authored by: Scottish-UK
Re: Wifi down
Same as my situation.
i have powered down the router and restarted but still no WiFi..
router lights are green for power, amber for internet, green for WiFi , amber for voice.
what's the process other than reboot router (which I have already tried) ?
Re: Wifi down
@Haddy456 the app is a nuisance as it takes up to am niur to pick up the connection is down which is pretty useless. You can try clicking to re-run the test as it can then tell you if Sky are aware of a fault in your area or simpky call Sky.
Re: Wifi down
I've run the service checker app, which as described above isn't smart enough to detect an issue.
[removed] open ling hours are 8am to 9pm...
The automated phone system sends you a text to the sky.com fault checker and says that you can raise a case online which is incorrect, so I will have to wait until opening hours of 8am.
Fault area: West London , (W5)
Info for others , I have run through the hard rest procedure of the router by holding down the small black button to reset to factory settings which did not resolve the issue, and the router now shows green for power,
amber for internet and green for WiFi.
Moderator note: removed internal phone number
This message was authored by: Galaxy88
Re: Wifi down
I have the same issue in W13. Sky app says no faults in my area but orange lights persisting after multiple resets.
This message was authored by: Aga84
Re: Wifi down
Same problem in W13 London. Sky app says no faults in my area but orange Internet light persisting after multiple resets.
This message was authored by: DanielTas1995
Re: Wifi down
I also have the same issue and am based in W13
This message was authored by: jamesfegh
Re: Wifi down
Same for me in W13.  Have just spoken to an extremely unhelpful Sky operative who told me that I could find an engineer locally to come and look at it today if I wanted then put the phone down on me.
Re: Wifi down
FYI , case logged with very helpful customer service agent on the  phone via tel: 0333 759 xxxx  including uploading photos or the router and phone socket.
No widespread faults reported at the moment, but they have just opened, I mentioned that there were a few people reporting issues here in the community section and the agent said that that team hasn't started for today yet so it won't be cross checked yet ...
The bad news is that the response time for the next level support team is... "You will be contacted in the next 72 hours "
This message was authored by: Jos4
Re: Wifi down
Same W13 , i guess we are the lucky* ones, i hope they figure the issue and can fix it.
This message was authored by: Meg414
Re: Wifi down
Same in W13
This message was authored by: zhao
Re: Wifi down
same problem in my broadband. it is down from this morning. online test says everything is fine. what can i do?
Re: Wifi down
Finally they find the issue....
Their saying:
"There's an outage in your area
We're working on getting you back up and running. It usually takes a couple of days to fix things like this but might be sooner."
Re: Wifi down
Outage in your area?
Yes
Service impacted: Broadband
Outage start date: 26 July 2024
We know there's an outage in your area. You don't need to do anything - we're working on getting you back up and running. It usually takes a couple of days to fix things like this but might be sooner.
When it's fixed, your service will automatically start working again.
Re: Wifi down
It will take a couple of days to get internet back? what a service from Sky. This will be my last time to use their service.
