Discussion topic: Wifi down East Cheshire
Message posted on 29 Feb 2024 03:01 PM
Anyone lost their WiFi around Poynton, Macclesfield, Stockport area?
Message posted on 29 Feb 2024 04:48 PM
Re: Wifi down East Cheshire
@Frankie007 You mean your broadband is down. If that is correct then you can run the broadband test to see if it gives you further information or finds an external fault.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 29 Feb 2024 05:35 PM
Thanks - ran the test and still the same problem
Reset the router - seems to have solved it
Message posted on 29 Feb 2024 05:42 PM
Yes it's just dropped me out of a zoom meeting and now won't connect at all,
