Discussion topic: Wifi disconnecting
This message was authored by: joyous43
Wifi disconnecting
Broadband losing signal and restarting again , just started happening over the past week
Re: Wifi disconnecting
@joyous43
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
