Discussion topic: Wifi disconnecting
Message posted on 23 May 2025 08:00 PM
Wifi disconnecting
Wifi keeps disconnecting at similar time everyday. Was fine before we moved where we had the same box etc. We're having to restart the router each time and takes a while for everything to connect again then.
Message posted on 23 May 2025 08:44 PM
Re: Wifi disconnecting
@Lauren288 Have you run the service checker or the Diagnostic test, both are below for you to do.
Message posted on 23 May 2025 09:01 PM
I have and they come out as no issues. Can only run them once wifi is back working where there is no issues with it at that point. Unable to check when wifi has disconnected.
Message posted on 23 May 2025 09:27 PM
@Lauren288 You cannot run them over mobile data?
