Discussion topic: Wifi cutting out
This message was authored by: Stuart19691
Wifi cutting out
My wifi keeps cutting out every 10 minutes.. Middle light goes yellow. Rebooted several times.
Re: Wifi cutting out
@Stuart19691
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
