Discussion topic: Wifi connection
This message was authored by: Lorna2025
Wifi connection
Hi we appear to have lost our WiFi connection and I'm supposed to be working from home, many thanks
Re: Wifi connection
@Lorna2025
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
