Discussion topic: Wifi connection
This message was authored by: Garryganpot
Wifi connection
I have no wifi connection
Re: Wifi connection
@Garryganpot
When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down after 7am use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
