Discussion topic: Wifi connection
Message posted on 08 Feb 2025 12:38 PM
Wifi connection
Hi our wifi connection is always down
Message posted on 08 Feb 2025 01:19 PM
Re: Wifi connection
@Mariam29
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
