Discussion topic: Wifi connection not working !
Message posted on 15 Apr 2026 05:10 PM
My wifi is not working i have checked everything and the service checker and it is still not working.
I have tried all let's fix it connections and it is saying my connection has dropped
Message posted on 15 Apr 2026 05:12 PM
Re: Wifi connection not working !
There are multiple posts on hyere reporting the same so I think it is fair to say there are some issues where you are.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
