Discussion topic: Wifi/ broadband dropping out
This message was authored by: Mike1103
I have had occassional issues with wifi and broadband dropping out however this is now happening daily at least 3/4 times a day. I have completed all the self help advice and this has not stopped it. I need this issue to stop due to my wife working from home, has meetings and everything is on line, as soon as it drops out my wife ends up losing work and missing meetings. The router and Q box have been restarted so many times and this has not fixed the issue, this is also time consuming and not condusive to the Sky promise of ultra broadband and streaming.
Re: Wifi/ broadband dropping out
Hi @Mike1103  Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
I am NOT a Sky Employee
Avatar for Mike1103
Router Statistics System Up Time: 33:37:07 Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 11392272 18686400 0 740730 28184 31:53:11 LAN Up 4257651 3148276 13 476980 38025 33:37:07 WLAN (2.4 GHz) Up 4282026 1023859 0 7198 400 33:35:10 WLAN (5 GHz) Up 10378179 5275774 0 0 622565 33:35:06 Broadband Link Downstream Upstream Connection Speed 159957 kbps 29992 kbps Line Attenuation D1(28.5 dB) , D2(0.0 dB) , D3(0.0 dB) U0(0.0 dB) , U1(0.0 dB) , U2(0.0 dB) Noise Margin 29.1 dB 22.5 dB Poll Interval: Seconds (at least 3s): 10 Set Interval Stop
@Mike1103
Your stats dont suggest any drops to the actual WAN port on your router. Are the drops you are seeing just over WiFi or also ethernet?
This message was authored by: MarinaFern
The same is happening to me.
Avatar for Mike1103
  • The internet drops at the same time as the wifi - i dont use ethernet except for the connection between sky q and the router - and yes this also drops out.
