Discussion topic: Wifi Signal is down
This message was authored by: HunterAlpha
Wifi Signal is down
Wifi has stopped working
Re: Wifi Signal is down
@HunterAlpha given the time you posted it is quite likely to be due to overnight maintenance work. If the connection is down in the morning then check the leds on the hub see  https://www.sky.com/help/articles/hub-lights-explained-start
