1
This discussion topic has been answered Discussion topic: Wifi Not working
This message was authored by: Kavya_jain
Wifi Not working
Wifi is not working from 25th October and is not fixed yet. Any update please
Re: Wifi Not working
@Kavya_jain
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
@Kavya_jain
