Discussion topic: Wifi Issues
Message posted on 20 Dec 2025 03:20 PM
Wifi Issues
Done multiple speed checkers online and used the sky service checker and it says everthing is ok however, when I use my computer there are multiple apps that are having many internet errors causing disconnects/latency issues and a overall a terrible performace (i have checked the apps serves and status and they are all fine) . We had an internet outage for about a week maybe a month and a half ago where someone had to come out to help fix the issue, since then the overall performance of the wifi has significantly dropped. I do work from home aswell so these incidents have caused lots of problems for me aswell.
Message posted on 20 Dec 2025 03:51 PM
Re: Wifi Issues
Totally agree, can't wait for my contract to end and I will switch providers
Message posted on 20 Dec 2025 03:53 PM
Re: Wifi Issues
@Josh061
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
