43
This discussion topic has been answered Discussion topic: Wifi Issues
This message was authored by: KaiMorgan
Wifi Issues
Broadband and wifi checker say there are no issues but devices see the wiffi but say they can not connect to the Internet.
Re: Wifi Issues
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
This message was authored by: Rak5
WiFi
WiFi not working. Service checker showing no issues however WiFi won't connect and is not working at all.  I am supposed to be having a new hub but have been chasing this for weeks via live chat.
This message was authored by: Leigh511
WiFi is down
Hello my WiFi is not working is the internet light appears to be off on the router for the last 10 minutes
This message was authored by: Elizakt
Re: Wifi Issues
Mine is down too- it stopped working at bang on midnight
Re: WiFi
Mine is down too- it turned off exactly at 12am
This message was authored by: BSheer1
Re: WiFi
Same issue here turned down exactly at 12:00
This message was authored by: SophieWB
Re: Wifi Issues
Mine too and service showing no issues.
This message was authored by: TizioCaio
Re: WiFi
Same issue, I'm in NG12
Wifi down
Wifi stopped working exactly at 12:00
This message was authored by: Emma518
Re: Wifi Issues
can't connect to WiFi but the checker says everything is fine. Clearly there's an issue.
This message was authored by: Rachie398
WiFi has gone
WiFi has gone hun is flashing green tried to reset it all and still doing the same, so how long before back on can't watch tv or anything
This message was authored by: ClaireHall
WiFi down
My broadband hub is not connected to the internet
This message was authored by: Laptop10
WiFi is down
WiFi is down. Saying no issues but there is.
Re: Wifi Issues
Mine is working again now
This message was authored by: Vizdragon
Re: Wifi Issues
Mine went down too.. midnight... apparently no issues....but def no internet
