Discussion topic: Wifi Issues
This message was authored by: LarniBurton
Wifi Issues
My Wifi is not working properly it keeps disconnecting me. and it keeps showing green when doing the tests. I am not sure what else to do.
Re: Wifi Issues
@LarniBurton
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Avatar for LarniBurton
Level 0 icon
Re: Wifi Issues
I have tried this and I dont have sky telephone to call 150.
Re: Wifi Issues
@LarniBurton
You have Sky Talk as it's bundled together with your broadband package. You've just chosen not to attach an actual phone handset.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
