Discussion topic: Wifi/Internet keeps cutting out
Message posted on 08 Mar 2025 09:21 PM
Message posted on 08 Mar 2025 10:29 PM
Re: Wifi/Internet keeps cutting out
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 08 Mar 2025 11:00 PM
Thanks for your reply.
I have checked & tested the connection multiple times & it says there aren't any issues.
I have reset the router multiple times too.
At my wits end tbh
Any other suggestions?
Message posted on 09 Mar 2025 01:58 AM
Jules did you manage to sort this problem? I have recently switched to sky fibre 150mbs and have had the same issue. I called sky today who had instructed me to reset the router "didn't work" or upgrade. I'm thinking of switching whilst in my 14 day cooling of period. Have you been with sky long or is this a recent problem as other people are having the same issue recently and say this issue has started in the last two week's. Hopefully it's not long term 😬
Message posted on 09 Mar 2025 04:19 AM
Hey Daisy
I've been on Fibre 150 since Oct 24.
Over the last 2 weeks, it has started dropping connection sporadically, but the last couple of days.....arch! 😠😤😡🤬 It's at least every hour.
I only reset everything about 2 months ago due to an app on sky stream kept disconnecting & not loading again for ages.
From your reply it does appear to be a 'sky' issue if affecting so many. My bad for not investigating further & finding that information myself. I appreciate you for responding to me.
I hope you get yours sorted...you could tell them that you will upgrade but only if they agree to let you return to cheaper option once this 'issue' has been fixed? Worth a try anyway?
Good luck 👍🏻
Message posted on 09 Mar 2025 11:27 PM
Apologies...I somehow missed your reply 😕
I will definitely follow your advice next time. Thank you so much. I will report back with the results.
Funnily enough, since I replied to Daisy, it hasn't dropped again 🤷🏼♀️
Coincidence?
Thank you for taking your time to respond...I appreciate it, and some faith in humanity has been restored 🥰
Message posted on 09 Mar 2025 11:31 PM
@caesarome I didn't tag you, sorry. My last message was to you.
Message posted on 10 Mar 2025 12:13 PM
Hey Jules thanks for the reply.
Mine has been stable since my reply to you so I think it may have been a problem with sky. I think I will not need to upgrade or cancel. Hopefully 🤞
