Discussion topic: Wifi/Internet down
This message was authored by: Jill_01_
Wifi/Internet down
Completed all the checks twice! Pulled all leads from hub waited 2 mins put all back in- still nothing! I need this for work- please help! All lights on hub are green.
Re: Wifi/Internet down
@Jill_01_
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
