Discussion topic: Wifi Extender
Message posted on 20 Oct 2025 07:55 PM
Wifi Extender
My installer said if i had any issues to contact sky to get some extenders. ive been trying to contact someone, but there seems to be no actual info on how to order them. I have 2 rooms where the signal is very weak.
Message posted on 20 Oct 2025 09:44 PM - last edited: 20 Oct 2025 09:46 PM
Re: Wifi Extender
@Bunglemaz76 You can only get them and if you are paying the extra supplement also, plus to get them you have to call sky direct, there is no other way for it to happen! Details all about linked below, so best check speeds just now as you will be tested by sky! Call 150 on your landline phone is the easiest way, also 150 if you are using a sky mobile!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
