Discussion topic: Wifi Extender
Message posted on 02 Jun 2025 05:54 PM
Wifi Extender
Message posted on 02 Jun 2025 06:20 PM
Re: Wifi Extender
@FuzzyPoodle Get the sky max addon, service. details below.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Message posted on 02 Jun 2025 06:45 PM
Re: Wifi Extender
Thanks.for your reply. I already have upgraded to the WiFi Max and still having the same issues.
Message posted on 02 Jun 2025 07:30 PM
Re: Wifi Extender
@FuzzyPoodle Thanks for the reply, obviously you never opened or if you did then you never read!
Message posted on 02 Jun 2025 07:45 PM
Re: Wifi Extender
Apologies if my reply was taken the wrong way. I was thanking you for the the articles. I do have WiFi Max and I have tried testing my WiFi and other suggestions from the help pages. I'm assuming contacting Sky directly might be my best bet. I was wondering if there was a straight link to getting extenders, clearly not.
Have a lovely evening.
Message posted on 02 Jun 2025 07:54 PM
Re: Wifi Extender
@FuzzyPoodle That is the only way to do it, you call them, they test exactly at that point when you call, decision is made, you either get or they say no everything is fine as far as we can see, then begins the confrontation....
Message posted on 02 Jun 2025 07:56 PM
Re: Wifi Extender
Oh joys. I might be easier moving house. 😂
Thanks for the help. You any good at phone arguments? 😂
Message posted on 02 Jun 2025 08:03 PM
Re: Wifi Extender
@FuzzyPoodle I think you will be fine, as you have tested the speed area's, lowest speed let them try to find your device it will be pant's with regards to speed tiled toilet door shut is usually the hardest to get, know what i mean.... Lot cheaper than trying to move lock stock and two smoking barrel's...👌
