Discussion topic: Wifi Down in LL11
Message posted on 22 Oct 2025 12:04 PM
Wifi Down in LL11
Anyone elses wifi went down at 11:34am today (22/10/2025) in the LL11 area?
all wifi status scans of the router say it should be working... it is in fact not working
Message posted on 22 Oct 2025 12:12 PM
Re: Wifi Down in LL11
@K4ts86
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
