This discussion topic has been answered Discussion topic: Wifi 7 router settings
Message posted on 31 Jul 2025 01:39 PM
Hi all. How come this fun? Anything need to be done on My sky app using your phone. Tried to separate the wifi networks, but this is a huge headache. How anybody with sane brain can make this garbage?
Message posted on 31 Jul 2025 02:20 PM
@Govle the ability to separate channels breaks WiFi standard like 6 and 7 which require the bands to synchronised to operate as designed. You should be able temporarily turn off the 5 and 6GHz bands while you connect devices that wont connect otherwise which should stay connected when those bands are re-enabled . Automatic channel selection is required to give access to the DFS channels in the tGHz band which can only be used if there is no higher priority user in range.
Message posted on 31 Jul 2025 01:49 PM
Re: Wifi 7 router settings
@Govle What is it that you expect for using wi-fi 7 features to a hub.
Message posted on 31 Jul 2025 02:30 PM
Thank you. Was just disabling 5G because looks like my phone was on that but on the phone looks like failed connection.
Laptop using 6G no issue. Now the phone working without issue.
