Discussion topic: Wiffi conection
This message was authored by: Derbyram
Wiffi conection
When on other wiffi I could sit outside and get a good reception since moving to sky I can't get a good signal Evan in the next room I have a problem
Re: Wiffi conection
@Derbyram
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
