Discussion topic: Wife issues
This message was authored by: AmySidebotham
Wife issues
Every day this week our WiFi has dropped. At different times across different devices. There's clearly an issue
Re: Wife issues
@AmySidebotham if a few devices are dropping while others remain connected it is unlikely to be a problem with the broadband connection to your hub. Far more likely is an issue with t he WiFi connection from the hub tomthe devices. It is worth rdbooting the hub as if the problem is intenrference from a neighbour's network thst dhould cause your hub to find a less congested d channel to use.
Beyond thst check the hub is in the best poition which is out in the open on a surfacecabove obstructions like radiators. However in many homes a single Sky hub will be unable tomgive usable WiFi in every room if the applies you will need an extender or similar.
