Discussion topic: WiFi
This message was authored by: Fionamaloney
Message posted on 09 Sep 2026 03:15 PM
WiFi
My WiFi is not working upstairs? Why is this?
Find out more
Message posted on 09 Sep 2026 04:43 PM
Re: WiFi
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
