Discussion topic: WiFi
This message was authored by: Kelsick+king
Message posted on 05 Aug 2026 07:42 PM
WiFi
I got my sky router installed today and it works but the WiFi seems quiet weak and has dropped out quiet a few times today toy sky box's, the speed at the router is high but is in my dinning room andt sky box is in the living room at the opposite end of the house
Find out more
Message posted on 05 Aug 2026 07:48 PM
Re: WiFi
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
