Discussion topic: WiFi
This message was authored by: Leah902
Message posted on 19 Jul 2026 07:23 PM
WiFi
My WiFi is not strong enough to connect to the back bedroom does not reach that far to connect wireless
Find out more
Message posted on 19 Jul 2026 07:48 PM
Re: WiFi
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
