Discussion topic: WiFi
This message was authored by: Liannekidd
WiFi
Every night at the same time, my Wi-Fi disconnects and has a flashing amber light in the middle when I tell me what this is
Re: WiFi
@Liannekidd your hub is losing its connection to the cabinet as the most likely causecis something nearby is causing interference thst is knocking out the conection. While it could be something outside your home ot most likely is something inside. Consider if something is switched on or off when the connection is lost. It could beca sparking connection, a microwave orceven a fluorecent light.
