Discussion topic: WiFi
Message posted on 24 Jan 2026 07:09 PM
WiFi
WiFi gone down
Message posted on 24 Jan 2026 07:12 PM
Re: WiFi
Message posted on 24 Jan 2026 07:13 PM
Re: WiFi
@EmmaScott @Jenii
See further down for guidance on the lights on the various hubs.
With broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
