Discussion topic: WiFi
This message was authored by: Dlklfc
WiFi
LOS light is red even after turning it off at the mains and restarting
Re: WiFi
@Dlklfc
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them so they can look in to this for you.
