Discussion topic: WiFi
This message was authored by: MariaConstantin
WiFi
I’ve been having major issues with my Sky broadband connection since this morning. I work from home, which is why I chose a high-speed broadband package, but from around 8:30 AM today the connection keeps dropping.
The WiFi shows as “connected but no internet”, the message appears and disappears repeatedly, sometimes every minute. This is making it very difficult to work.
Re: WiFi
@MariaConstantin
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
