Discussion topic: WiFi
Message posted on 16 Sep 2025 08:15 AM
WiFi
The WiFi is hardly working
Message posted on 16 Sep 2025 10:39 AM
Re: WiFi
@Rio9
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
