Discussion topic: WiFi
This message was authored by: Stu011
WiFi
I can't get WiFi to work
Re: WiFi
@Stu011
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Re: WiFi
@Stu011 As you have posted on multiple boards on the Forum, is it Wireless Wi-Fi signal only or NO broadband internet, one is not the other!
