Discussion topic: WiFi
This message was authored by: Wendy-Clubbe62
WiFi
WiFi keeps dipping, trouble connecting to tv and internet. Connects and loses connection within  minutes and requires waiting for re-connection.   Router is more than 10 + years old. Could this be the cause.  it is so disruptive and irritating.
Re: WiFi
@Wendy-Clubbe62
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Re: WiFi
@Wendy-Clubbe62 Take a look also at the link below and say which sky hub you have!
Re: WiFi
@Wendy-Clubbe62 Trying to establish if you have the older Sky Q or the Sky Hub as both are heading to obselete status come Dec2025 for security reason's and sky in the midst off a change out program with those two units!
Avatar for Wendy-Clubbe62
Re: WiFi
Hi, I have the Sky Hub
Re: WiFi
@Wendy-Clubbe62 Just in case you have been missed, no letter, no e-mail etc link below to get the replacement that will be the Sky Broadband Hub and it is free to you!
www.sky.com/skyhuboptions
Re: WiFi
Thank you so much for this, not aware that I have received any notification.  I will action today, again many thanks.
