Discussion topic: WiFi
Message posted on 18 Jun 2025 07:36 PM
WiFi
good evening, again I am having issues with the WiFi in my home. This is consistently dropping out and causing problems with me working from home as well as limiting my access to TV services
Message posted on 18 Jun 2025 07:40 PM
Re: WiFi
@Mcd764658
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
