Discussion topic: WiFi
This message was authored by: Mark541
WiFi
No WiFi again
Re: WiFi
@Mark541
Wi-fi or broadband? Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
